MPG
1996 750i
X1 gearbox service
Morning Cornel Welcome to the Forum Your Gearbox is ZF GA8HP45Z which I believe ZF advise should be serviced every 60 to 100000 km dependent on environment and use (Climate Towing etc) If you feel like teasing your local BMW Dealer service manager ask him if it's sealed for life why do BMW have a gearbox service kit on their parts list 😅 Transfer case is ATC 35L Personally if it is running well and at the low miles you have it isn't an urgent priority. 12 years is a stretch I would look for a good Independent or better a ZF Transmission Specialist if you can't DIY Dave -
Need help identifying burnt part on water damaged Harman Becker amplifier. Part # 9320214 - model BE B220. I am trying to repair this unit and one component is burnt beyond recognition. It has 4 pins and is SMD package. Attached are pictures of where the component is on the PC board. If anyone has an amplifier that is model BE B220 or similar and could take a high resolution picture of the component so I can get the SMD code from it I can look it up. -
X1 gearbox service
Hello. I recently bought a X1 20D auto, 2012 with 8k miles on it. I'm thinking I have to change the gearbox and transfer box oil/fluid purely because of the age of the car. BMW dealer stands by "seal for life" crap but I'm not sure what to think. It's basically 12-13 years old fluid in there. I've read previous posts about ZF recommending at 60k miles for gearbox oil and 30-60k for transfer boxes fluids. In my case, at 8k miles do I need to change it? Thanks 👍
