BIMMEROWNERSCLUB.COM first show!!!!
Profile setting
I have 2025 X3 I have created a profile for myself and then I set up another profile as ‘driver2’ when I use my key it picks up my profile but does not show my 2nd profile I have tried to set it up again but it shows on the screen as driver 2 is already set up but I cannot find the profile anywhere any help is much appreciated -
X3 Door locks
Thanks for the reply. It's passenger and rear doors and tailgate, but only occasionally. I'll look at a replacement actuator and see if that solves the issue. 👍 -
X3 Door locks
Welcome Paul. is it all the doors stay locked at the same time or a random one? my Porsche’s rear right started doing it and it turned out to be the door actuator. if it’s all at the same time every time, I would look at the relays as it’s giving a signal to all doors. Random 1 door will be getting the signal but failing to actuate -
X3 Door locks
Hi all. Newbie to the forum. I have a 2018 X3 M sport 2.0D I have set all doors and tailgate to unlock when the engine is turned off. Sometimes they do unlock and on the odd occasion they remain locked. Has anyone experienced something like this before. Thanks in advance. -
suspension / service
Morning Jerry BMW use a complicated spring rating system the Dealer will need Chassis Number etc etc and then a Body Part as a deposit 😅 Bilstien are OEM suppliers among others so that is where I would start for Springs and Shocks Dave
