ABS Module
Just fitted alternative ABS module. ABS warning light is now out but ASC light sometimes stays on and is intermittent. Can anyone tell me how to fit. Since intermittent assuming its an electrical fault?
Morning Alan
If my old brain is functioning your car has a combined ABS/ASC unit and from memory again I didn't think there were alternatives (but I am old) Just had a quick look at ISTA and my old brain is working😅 There was only one part number for your model 34511090911 if you have the correct part number the only thought I have is that as the Unit is combined ABS/ASC one of the valves is sticky so you get the intermittent fault. Do you still have the original ? try swapping the electrical (brain) part or send it off to someone like ECU Testing who specialise in repairing these units
Good luck Hope this helps
