Guys I have a mega problem I have loads of steam belting out from my bonnet. I turned the car off and let the steam go away as I couldnt see where it was coming from bbut when I started the car up again I noticed steam coming from a hoase which is split a little which looks to go into the inside of the car. The temp gauge was in the red before I stopped the car etc. But what hoase do I need and where does it go too. It's a 1998 316i compact. I need help asap. Thanks
the hose you need to change sounds like a Heater Matrix hose, Get a new one(BMW dealer will do the job) re fit and hope it hasnt done any more damage,if it wasnt in the red for too long you may get away with no other damage,
new hose time!
Could I get the repair tape from halfords ( that good stuff lol) just until tomorrow could that fix it for a little while? Also would that be why my temp gauge sat in the middle after a few mins driving?
Pressure is needed to push the water around the engine (as well as other things). With a cracked hose, pressure is lost therefore it will overheat. New hose just as Ian said. I have the same car as you and parts are quite cheap and still widely available so dont worry.
Repair tape will fit it for a while but no way a perm fix so get that hose asap.
If you get a pic of the hose, we can tell you exactly what hose to get.
Daz
It was just repair tape until I got home. I will get a picture tomorrow morning and upload it asap. I need it for to go away in about 2 weeks once I get a picture can someone maybe help guide on how to remove it and easiest way to get the other on?
Thanks
Dont put tape on it,fix it properly
Tape has got me out of many sticky situations in the past. If you need to use it to get yourself out of a pickle, yam it on there! and repair asap. Don't advise using it for 2 weeks though dude.....
Get some pictures up and we shall assist. Unless its a difficult to get to hose, you wont need a 'how-to-guide' as it is simply two jubilee clips.
I must admit i have heard some storys about the tape giving up and leaking when under heat and pressure
I have the pipe off, it is just 2 jublee clips which are a nightmare to get at lol. I will try to get a picture up asap of it as i cant find the webcam app on this computer lol. to explain it in a simple term its like a shape of a J
A pic of where the hose sits in the engine would be good to give an idea of which it is but I'm sure if you go to your local BMW garage with the part they will be able to order it for you :)
Sam
You may be able to get away with cutting the damaged end off and refitting it, be it a tad shorter!
Half does ! :huh:
Sailed there a few times, and was quite confusing !
    3. 7
    4. 0
      Wheel cleaning
    5. 14
    • Andrew2112 earned a badge
    • Lazinsky earned a badge
    • Edgie7 went up a rank
    • Edgie7 earned a badge
