Clubsport Or M Sport
RHD right hand headlight
Hi, thanks for your input, but I've finally found a lens in Australia. It's exactly the right one, so good result. Phil -
Scraping sound under centre console on hard acceleration.
Hi Kevin Well looking at www.realoem.com it looks as though above the Propshaft you have a bracket to support the Handbrake cables item 6 at the front directly over the Prop and Item 12 to support the split of cables left and right I would start there it may just need replacing or short term a couple of cable ties applied Hope your up and around soon Dave -
Morning all, So my car started making a scraping sound under the centre console when accelerating hard, Ive found on another forum a video with the exact sound I’m experiencing. Turns out it’s due to the handbrake cable clips above the fuel tank breaking and the hand brake cables rub on the prop shaft. Has anyone got any experience with renewing these? Apparently the tank needs to be dropped. People have said that cable ties work well as a cheap alternative. I’d normally climb underneath, play and report my findings, but I’m recovering from an operation at the moment so cannot get underneath for a few weeks. 😕 -
735i - heater element water thermostat - please help
Morning Dimitris Just checked my wiring diagram in ISTA and it doesn't cover E38 models so not much help at the moment but I will dig Dave
