Ill give £20 to the last person to post on this thread
Heaters blowing hot air on drivers side when AC is on
Hi there. I have a 1 series 2022 and just recently when I go to drive it sometimes the heaters on the drivers side and blowing out hot air even though the AC is on!!!! The passenger side is fine and normal but on the drivers side its hot air. and it doesn’t happen every single time, but its !Removed! annoying when it does!!!! anyone had anything similar????? -
new member
Morning Gary Welcome to the Forum That looks very smooth and slick congratulations Dave -
Did the E61 have a non-slide sunroof?
Morning Oliver Welcome to the Forum As far as I am aware they should be Tilt and Slide. There were some well documented incidence of them failing over the years and they can be a pain to fix from what I have read. Never done one personally, that may explain your specialists reaction. You could use a Vin Decoder to get the original build sheet the item to look for is S402A electric powered roof Dave -
Exhaust gasses in an X3
hi kevin did you get your car sorted with the fumes ? as mine is pretty bad thanks
