BIMMEROWNERSCLUB.COM first show!!!!
New member
I’m new to the forum as well as to BMW automobiles in general. I just purchased a 2013 BMW 320i Xdrive with just under 57,000 miles for my son as his first car. Looking at service records the timing chain, valve cover gasket, oil pan gasket, brakes, and rotors were replaced around 45,000 miles. Are there any common issues these cars tend to have that I need to be aware of? The only thing I’ve found is one of the reverse light housings is broken on the side next to the tail light. A common problem if you don’t remove the housing correctly from what I’ve read. Feel free to give me any advice or info I may need to know. -
650i crank no start
Good morning Dave Thanks for the reply, towing it isn't in my best interest I would like to get it running. And the parts car runs it just has no title which is why it's a part out car, which is good for me. I did a little research on the ews immobilizer code I got and that seems to be where my problem lies. Considering it ran one minute and not the next, and it's the code it's throwing. As both fuel and spark systems stopped working. I will check all the sensors as well I know bmws can be weird if they aren't getting signals from maf or others. My 135i was a similar case to this one and it was just a maf sensor. I opened the Schrader valve and tested fuel pressure it had plenty of pressure and flow. I don't know why that would knock out spark too though. I'm just not really sure how to fix the ews fault there isn't a ton of support for this car. I had a hard time even finding a fuse diagram. I am going this Friday to try again so any help with fixing that code would also be appreciated. Thanks -
Wireless charging?
My 320d has wireless charging, however my s24 ultra doesn't seem to like it I have had a "phone too hot remove from charger" error (from the phone) once or it simply does seem to get much of a charge. The LED goes blue when I put it in the tray. Advice appreciated. Rich -
Just purchased 320d Touring
Hi All, Just purchased a 320d M Sport Xdrive Touring 2019 40,000 miles. £25k. Really liking the car, I was trying to get A4 Avant Quattro but struggling to find one I liked/right price. Tried the 320 and decided to go for it, purchased from main dealer so probably paid over the odds but at least it's fresh MOT and serviced with one year warranty and free boot liner and dog guard thrown in. But cheesed off they didn't top up AdBlue or fit the dog guard properly. Two quick questions: Is my model G21? Do they still do/where would I find the sticker that lists the options the car comes with (in my old Golf it was in the spare wheel well)? Cheers Rich -
Parking Break Failure
Afternoon Darren Just your BMW telling you that you needed a Dealers help 😅 Or hoping to scare you into their arms Try a Parking Brake reset, as you only changed pads a Soft Reset should work Turn on the ignition. Hold down the parking sensor button for 3-5 seconds until you hear a beep. Release the button, and the system will reset Hope that does it for you Dave
