BIMMEROWNERSCLUB.COM first show!!!!
Wireless charging?
Morning Rich First is the wireless charger OEM or aftermarket ? Second is your phone compatible with the charger? (it seems not) I only know 1 person (our son inlaw) who uses wireless charging he is an Apple user and the system in his 3 series is OEM he has no issues Dave -
New member
Morning Shawn Welcome to the Forum Lucky son 😁 Even Dealers technicians (they don't call them mechanics anymore so they can charge more 🤣) can be clumsy rock apes at times. With the Xdrive cars correct sized tyres are essential to protect the Xdrive transfer case, diffs etc Hope your boy appreciates his car Dave -
Just purchased 320d Touring
Morning Rich Welcome to the Forum Enjoy your Beemer If I am right your model was in a change over period so could be G21 or F31. If you look at www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model. The site is a BMW parts site as used by Dealers so really useful if buying parts and seeing where they fit. Again you can use a BMW Vin Decoder to check your cars original build sheet. Hope this is helpful Dave -
New member
I’m new to the forum as well as to BMW automobiles in general. I just purchased a 2013 BMW 320i Xdrive with just under 57,000 miles for my son as his first car. Looking at service records the timing chain, valve cover gasket, oil pan gasket, brakes, and rotors were replaced around 45,000 miles. Are there any common issues these cars tend to have that I need to be aware of? The only thing I’ve found is one of the reverse light housings is broken on the side next to the tail light. A common problem if you don’t remove the housing correctly from what I’ve read. Feel free to give me any advice or info I may need to know. -
650i crank no start
Good morning Dave Thanks for the reply, towing it isn't in my best interest I would like to get it running. And the parts car runs it just has no title which is why it's a part out car, which is good for me. I did a little research on the ews immobilizer code I got and that seems to be where my problem lies. Considering it ran one minute and not the next, and it's the code it's throwing. As both fuel and spark systems stopped working. I will check all the sensors as well I know bmws can be weird if they aren't getting signals from maf or others. My 135i was a similar case to this one and it was just a maf sensor. I opened the Schrader valve and tested fuel pressure it had plenty of pressure and flow. I don't know why that would knock out spark too though. I'm just not really sure how to fix the ews fault there isn't a ton of support for this car. I had a hard time even finding a fuse diagram. I am going this Friday to try again so any help with fixing that code would also be appreciated. Thanks
