Hi
new to forum, I have an X5 2016 reg xDrive 3.0d MSport
can someone give me advice, what are the wheel widths on my X5? from what I have gleaned from the internet (as below) they are 9" front and 10" rear
the current wheels are:
255/50/R19 (front)
285/45/R19 (rear)
Morning Stephen
Those sizes are correct for a 19" staggered wheel set
You could use a BMW Vin Checker (Google) and your cars Build sheet will come up you will be able to see what wheel type your car was ordered with.
It will show something like Wheels type 448
Then check www.realoem.com (put the last 7 digits of your Vin into the search box) and it will give the part information and sizes
If replacing Tyres make sure that all 4 are from the same manufacturer that way you stand a better chance of front/rear rolling radius's matching, if they dont you risk transmission/transfer case damage.
I am looking to replace the wheels and tyres with 20" as below
Morning Stephen
The summer wheel/tyre set up on my X5 4.6is is Front Type 87 91/2 J ET45 Rear Type 87 101/2 J ET30 tyres are Front 275 x 40x 20R Rear 315 x 35 x 20R Winters are 18" square set up 255 x 55 x 18 Wintrac Extreme
My 20" Star Spoke type 87 are OEM that came with the car. Looking at the offset range you quote are these Aftermarket wheels ?
