Hi Newbie Here
Engine misfire
Morning Andrew Your description sounds like fuel delivery so worth checking fuel rail pressure and sensor as a starting point. Also an Injector check (don't know how many miles you have done Inlet side all Vacuum lines and pressure hoses good (no cracks) throttle body OK Fuel filter OK Dave -
11
Morning Tino Nothing from James just mailed him as a prod I brought an X5 E70 cheap as a project the previous owner had spent a fortune changing parts and finally lost patience with the car. The fault list was huge but after a lot of digging I discovered BMW use earth switching so started working through all the multiple earth points that helped (Not much but it helped) Next while inspecting the loom in the boot I discovered cable splices/joints covered with a clear plastic sleeve (couple of pictures attached) when I moved one it just fell apart, turns out the joints are twisted and compressed then covered with the sleeve. If moisture gets in the joints corrode (black residue) and come apart. I am not sure when BMW started doing this so maybe worth checking yours. I spent an hour or so stripping these joins and soldering then sealing with shrink wrap. I was able to see all modules for the first time and clear down all fault codes and fault memory. That was 3 years back and almost 40k still need to keep an eye on it after all it's a BMW 😁 When my sons friend brought his copy we had to set up VM ware and a Virtual Machine running Win 7 on his Win 10 Laptop initially getting the Drivers to work was a pain at first we loaded and reloaded them several times before we could get it to run cleanly. For drivers you could try ESYS (that's where my copy came from) Also check whether you need 32bit drivers or 64bit Dave -
11
Hello there Dave 👋 I kind of put the OBD port issue on the back burner since the late time I responded, figured I'd button up the rest of the car first since I'm not getting anywhere at this time. I haven't checked the wiring on the DME side yet so I need to do that as well. Did you ever get anything back from James on the matter? I poked at the Ediabas.ini file and made some adjustments per someone else's recommendation but that didn't work either. I restored the file back to original since. I'm gonna attempt to reach out to a BMW tech from Japan to see if I can find out any more information on these 320i's and see what I can find. What are the odds that this issue is module related? I'm also wondering if there is an issue with my Cable or the drivers themselves. Where can I get a copy of just the drivers to reinstall? -
21
Hi Greydog, While I had some troubles loading INPA from my laptop, I want to report back that I have successfully re-coded the RDS module using Pro Tool. Now all is working perfectly! Thanks for all your previous help! Best, JC- 1
Engine misfire
Hi, i have an E61 2008 530 d m sport and when I give it the beans it starts misfiring unless I back the foot of. If I drive it normally it settles down. I have noticed it behaves like this when I come off a roundabout i particular. any ideas guys. thanks Paneuro.
