Be Gentle I'm New Here
Hello We have a LHD X3 we use mainly from driving from UK to Greece - the tailgate lifts perfectly well but on closing it stops halfway down - it will continue and close properly with some gentle assistance on the way down. The car was MOT'd at a BMW main dealer a couple of days back, we had a free visual inspection and I asked them to investigate the issue. As per BMW the 'motors are on their way out'. Given that their quote was shall we say rather strong (I appreciate it is a quite tedious job to replace them) my question is are the rams serviceable or are they really a replacement job? -
10
Morning JC Look like you brought a scanner that just does TPMS systems ?? I have 2 Diagnostic scan tools (1) BMW INPA/ISTA which is the same as BMW Dealers use and (2) iCarsoft both systems will give me a code that indicates which wheel sensor is at fault or if it is the Controller. Plus of course they also read all other control units on the car. With your monitor what does the Instruction book say? does it give a list of codes and their meaning? TP sensors do fail some have batteries in them they are not expensive to buy online (Ebay, Amazon etc) the costly bit is to fit them, obviously tyres need to come off and be refitted. If it was me I would wait until tyre change time Dave -
10
Thanks Greydog! I have not tried the battery unplug. But I have purchased Autel TS508 to try out and it found the error below from the ODBC scan. I tried to erase the DTC from this menu and the TPM is working again until I left the car for a few hours. Does anyone know what is causing the error? Thanks! -
No boost and strange noise
Many thanks for your input Dave. My car does have twin turbos. I checked for play on the cold side of the larger/bottom turbo by removing the air intake but I take your point about the hot side taking more of a hammering. I can feel the actuator move at the vacuum box but I can't access or see the point where it connects to the turbo. I don't know if the flap moves freely - maybe the hot side is full of carbon as I tend to do short trips. Time to dig deeper so I've just dropped it off with a local turbo specialists who say they can run diagnostic tests and do a route cause analysis. The car has only done 55,000 miles, full service history with oil/filter changes every 4000 to 5000 miles so I'm hoping the turbo hasn't failed already 😟 Thanks Jim
