E90 Starting Glitch
acrybb
I accidentally discovered how to start my car without the key inserted (Push button starter).
If i put the key in Start the engine like normal then switch off the engine remove the key put it in my pocket then start the engine again every time it works.
You can do this until you lock the doors then it seems to arm whatever the key unarms. It also stops working after the engine has been off for a period of time.
Anyone know anything about this?
Andy
Try this... Start it with the key then stop and remove key... Then start with the button and leave it running, get out with your key in your pocket (Engine running) and walk away making sure there are no thieving twats around!! :lol:
I think its the transponder in the key that allows this function !! B)
It won't make a difference, it will run till switched off without key.
It won't switch off at a certain distance unless your car has keyless entry/start, which it don't.
Also it ill stop start, stop start after the first start stop until you have opened the door because it has already paired the key with the car and the ignition don't shut fully off till you open the door.
      Locked out of a 1990 525i
      E66 76Li - help needed with errors
      Noob
    • DHTL earned a badge
    • Delvic earned a badge
    • Wolfgangk earned a badge
    • Luckysod earned a badge
    • Bluebeard earned a badge
