New Club Banner
Morning Tino INPA/ISTA should recognise Chassis and ECU data and harvest it automatically, well mine does. I get Chassis information, Engine and any history recorded Just sitting with a Coffee studying the wiring diagrams up to 2007 and 2007 shows a resistor symbol in connector X13376 at Pin 1 Green/brown trace 2007-2009 shows no resistor symbol anywhere X13376 connector appears to be part of the vehicle access system it links to the DME Pin 2 Black/green trace that is part of the Start system Later today I will try and talk to an ex neighbour who is now a senior guy in BMW see if he can find any more help Dave -
7
Hey Dave 👋 I'm back! I'm wondering if the resistor is causing software not to be able to communicate with the ECU because the initial connection is normally established. The issue is when further communication starts then it just falls off and goes dead. Even with INPA, I borrowed a laptop with INPA from a friend that works on BMW's and it's acting strange. INPA sees ignition on all the time once OBD adapter is connected with a light on at all times on the adapter. The light on adapter stays on until getting into any sub menu. For example, E90>Engine>N45/N46. The light goes out and when entering the engine option menu I get an error "Group file : D_MOTOR. IFH-0009: NO RESPONSE FROM CONTROLUNIT. Program will be stopped!" After pressing okay it takes me back go the main menu. Also, when entering the "Functional Jobs" menu, and trying to enter the E90 menu I get the error "Language variants do not match. Malfunction possible!" After pressing okay it takes me to the E90 Menu under functional jobs. When I try to press on identification or vehicle data I get the message "no response from the control unit." I want to note that whenever I enter a new menu the adapter light blinks rapidly for a few seconds like it's showing me some type of data communication is happening then it just stops. I'm wondering if the settings of INPA need to be configured a particular way in order for it to communicate with this BMW or if a module has gone bad. Hmm, maybe I need to test the resistor to make sure it's fine. Maybe just get rid of the resistor all together? I'm not sure what it's purpose is but if all other E90's can operate without it then I'd imagine it'll work without em as well but not gonna jump to any conclusions yet. -
20
Hi Greydog, Thanks for your time checking on the i-Carsoft unit! I will be looking to obtain a copy of the ISTA then! Best, JC- 1
20
20
Thank you Greydog for your help! Yes, the Maxi unit reprogrammed the RDC but it does not correctly erase the old RDC coding data. That’s why it only work until I stopped the car. Now I know I need another tool to get the job done. 🙂 I will be waiting for your answer! Thanks!
