2011 X5 Transmission Light
Hi,
I'm new to the site and my 2011 X5 40d E70 is my first BMW (possible my last). The transmission light comes on. I've had it in the garage and the fault code is 4E9B. The garage have advised that the car needs to go to a gearbox specialist. Any advice would be greatly appreciated ☺️
Morning Christine
I would be concerned about your garage as the only time I have seen that code was on an X5 with an incorrectly fitted battery (IBS not connected)? First I would point out that I am not a garage just an old engineer with an insatiable need to know 😅 I also have a fully up to-date BMW Diagnostic program and have worked on my own X5's since 2002. Google the register of BMW Specialists you should find one close by
I would start with the battery, get the Voltage checked at the Charging points under the bonnet. Engine off it should show 12.5v minimum with the engine running 14.5v min. Also check the battery connections in the boot make sure the IBS (small lead) is connected
Hope this helps
Thank you for replying Dave. I have watched a few YouTube clips and Googled everything I can. The battery is something that came up a few times. I spoke to the garage about this and it is going in on Tuesday so they can check the battery before I start spending stupid money. I will let you know how I get on ☺️
Hi Christine
BMW's are well known for being sensitive to Battery voltage I have seen quite a few with either a parasitic discharge or discharged battery. The discharged battery will still start the car but diverts all energy to the start triggering all sorts of spurious warnings. For your information if the battery is charged on the car it should only be charged from the charge points under the bonnet. At the battery your car has an IBS lead (Intelligent Battery System) which lets the cars system know if it is charging or not. I have seen a few BMW's that have batteries changed and the lead has not been reconnected
Transmissions are pretty robust but just like the Engine do need servicing
Hope you get it sorted
Thanks Dave
I will pass on your advice to the garage. Fingers crossed 🤞 I'm really hoping it is the battery. I will update you on Tuesday ☺️
Hi Dave,
No luck at the garage 😔 They checked all the connections, all ok. They disconnected the battery, which was left overnight, ran a diagnostic test again this morning and the same error code came up. They still say I need to take it to a gearbox specialist. Any advice would be gratefully appreciated ☺️
Morning Christine
Is the garage a BMW Specialist or the Garage that sold the car ? I don't know what tests they carried out leaving the battery disconnected is a BMW Dealer trick to clear codes
Talked to a friend who works for BMW in the US apparently they saw a number of these faults which requires a Gearbox Software reset or upgrade Dealers can do it using ISTA-P or a ZF Specialist is the next step. Here is what he sent me
240211.pdf
Hi Dave,
Not a BMW garage. I have found a local gearbox specialist garage. Thank you so much for the information, I will certainly be showing them this. I will let you know how I get on ☺️
Hi Dave, car is booked into a local garage for Tuesday 10th. The guy who owns it is an ex BMW mechanic. 🤞I can finally get sorted. I will update you ☺️
Hi Dave, happy to report the car has finally been sorted. It turns out that the gearbox oil was very low. They have cleaned it out and put new oil in. Luckily, there doesn't appear to be any damage to the gearbox🤞. I will see how it goes. Thank you for all your advice, I really appreciate it. I know where to come if I have any other problems 🙄 xx
