1st BMW (2012 X5 40d)- Need help
Hiya,
First time owner, first post etc and I'm here looking for a bit of help please.
Bought a 2012 BMW X5 40d (125k miles) from private seller just before Christmas from private seller with FSH etc. However, on the drive home I'd noticed a strange noise......
Long story short, the front diff has gone (leaking oil) and I clearly need to get it replaced as it's very noisy and the smell of oil into the cab is horrible. I can't justify a brand new OEM part, and I'm nervous about getting a chinese one off of eBay.
So I thought I would put a post out to see who people would recommend within the UK? I've seen a couple of companies that do reconditioned ones, but I'm not sure that my existing one would be any good to return for a surcharge refund. I am also slightly confused with part numbers. The place I took it to to have a look for me were very helpful, and gave me a print out, but it lists two part numbers : 31508635861 (I believe to be a discontinued part?) and 31508635860
There's also a couple of other niggly bits with the car I'd like to get sorted:
Rear wiper mounting split - I'll either fix or replace
Drivers door handle light - advice needed, where to buy and how to fit
Front Window Washer jet - end one has broken, I've made a temp fix for now
Unlock crack - sometimes when I unlock, I can hear a cracking noise on the rear left, seems to be around the wheel/handbrake
Obviously those smaller bits can wait until I've got the bigger problem sorted out.
If there is someone out there who could point me in the right direction, it would be greatly appreciated.
Many thanks in advance
Morning Rhys
Front Diff damage is normally caused by mismatched tyres so before spending your Hard Earned money make sure Front and Rear tyres are (a) the correct sizes and (b) all the same make and wear. It only takes one tyre to be out of sync to cause Transmission Wind up and damage.
Front Diff you have the Part Numbers the discontinued and it's replacement either will do check online but also check BMW specialist dismantlers such as Quarry Motors. As for fitting if you can DIY it's obviously cheaper if not a BMW Specialist or good Independent Garage is the route. Once sorted I would change the Transfer case fluid and Rear Diff oils as well if I recall your Rear Diff has 3 chambers and needs 2 different fluids
As for the rest if you are not aware check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model, then search the different sections it will give correct part numbers and small exploded drawings which help to see how where things fit.
If someone has had a fiddle with the Door handle the small LED may have just fallen inside and only needs refitting (seen several)
Hope this helps
Good Luck
Hi Dave,
Thankyou very much for your detailed response.
Annoyingly I didn't get a handbook with the car, but I will have a look and see if I can find out what tyres it should be running. I did find the info on the tyre pressure sticker on the pillar and can confirm they are the correct sizes. Really useful tip for future reference though thanks. I am on the Quarry Motors site now, and that looks like a great option so many thanks again for that shout!
While I was with the car, I checked to see if I could see the LED on the handle, which I could, so I will use that site to have a look at getting that sorted too.
Is it worth me updating the software on the car? I noticed it seemed to be quite out of date, but obviously don't want to mess anything up.
Thanks again,
Rhys
Hi Rhys
Worth asking Quarry if they have a Handbook for your model
As your car is a 4.0d I would guess Fronts are 285x40x20 and Rear are 315x35x20 Tyres need to be same make and wear across axels and front and rear. BMW X series are sensitive to small differences in rolling tyre diameter I check by making a chalk mark at the bottom of the tyres front and rear with the car parked on a flat surface roll it forward 2 or 3 revolutions all 4 chalk marks should be almost in the same place. If they aren't there could be a problem ahead
I am uncertain what you mean by Software upgrades the Infotainment and Satnav is about all I can think of the Engine DDE is set as is the Gearbox (that is ZF software anyway) when my E70 needed Satnav upgrades I changed the whole screen to an Android unit the complete screen was cheaper than the Satnav software from BMW plus it is freely upgradeable gives Android Auto and Carplay plus I no use Spotify for most of my music now and the unit still allows all the BMW OBC functions as well Plus Plus for me
Hiya,
I've got 275/40 R20 front, 315/35 R20 on the rear, brand new Michelin Latitude Sport3 all round when I got it. That being said, I have no idea how long the diff issue has been there prior to me.
Software, yeah I was referring to the infotainment system, only because it's got a 2012 date on it. Certainly not looking to start messing with anything else at the moment, and not looking to buy any software. To be honest, I've used Google Maps on my phone as a SatNav for years, and have been thinking about upgrading the unit for a Android one (I'd get cameras too while I'm there). There's a guy near me that seems to specialise in them, https://www.bavarianwizards.co.uk/ , that I am planning to get in touch with.
I spoke to Quarry Wood, and unfortunately they don't have any diffs for me at the moment :( but if they do get one, I'll ask about the handbook. I downloaded a couple of BMW apps yesterday and have found a pdf version, which is better than nothing I guess.
Hi Rhys
My guess would be that the diff issue was prior damage and that's why you have New Correct tyres now.
There is a Register of BMW Dismantlers worth a Google and try a few others. If you aren't aware try www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model, then search Front axel. When you have the part numbers if you double click the part number you will get a list of alternatives plus a list of other models it was used in. It may help widen the search
OK, I have a bit of an update.....
I managed to get hold of a replacement front diff from Silverlake.....came next day, and looks fairly healthy, 6 month warranty. However, the very next day, as I was getting kids in the car for breakfast club, there was an almighty screech from the rear left as I shut the door. Get in the car, "Parking Brake Failed" error message, and the wheel is firmly locked.....
Spoke to the garage I was going to take it to for the diff replacement, who are busy for over a week, stating it's a fairly common but expensive fault.
I've attempted to free the wheel up, using all the methods that Google/Chat have suggested, to the point where I simply cannot get the brake disc off, and I didn't want to cause further problems where the car is.
So, I am investigating recovery, but where should I go?
A ) Recover to garage and wait until they can look at both problems
B ) Recover to home, see if I can get the disc off or get a mobile mechanic to assist
C ) Recover to home, see who can look at it soonist, and then re-recover to there
Any other ideas and/or suggestions appreciated,
Hi
Left side of the boot rear cubby there is a manual release for the Parking Brake, if you haven't found it. I have seen one where the shoes were badly worn and it allows the Parking Brake mechanism to over wind and jam (the screech) then a chunk of shoe material had detached, I released the PB then reversed the car which freed the brake. New shoes and a reset of the PB all good. It sounds like yours may have had a poor maintenance back ground
Hi Dave,
Yes I think you may well be right there. I've found the cable, and it appears to do nothing......some info suggestion it might need some force, hence the red tool (which of course I don't have either), but I've given it everything and nothing happens, so I suspect that may have been used in the past too. If I can get it back home, then I'm comfortable doing pads/discs etc.....If she needs some TLC to get her healthy for another 50K that would be good, but I can't afford to spend 1000s on her.
Hi Rhys
If the cable has a Ball on the end it is OEM if it has a Loop it is probably an aftermarket replacement not that that's a problem just indicates it has been changed before. I have seen one where the EPB unit had been replaced 3 times by the owner but he hadn't checked shoe wear and adjusted them ??
I needed a Claw hammer to get enough leverage to release the jammed cable. When I took the unit off the car I took it apart and was actually able to release it internally and save the unit (he has it as a spare now)
Like most things on a car if it's looked after it will last a long long time
That sounds like it could well have happened it...... I can't get the wheel to turn, I've been underneath and unbolted the handbrake unit to give it some slack, but still nothing, so I think I now need to disconnect the cables completely, and then surely I can encourage the wheels to turn enough to get to the adjuster screw/rotor.... That's my plan anyway, if it doesn't work then recovery on the credit card, but everywhere seems to be full booked for over a week as well
Morning Rhys
To release the cables you need to remove the Disc/Drum assembly if it is Drivers side you may be able to release the cable at the actuator end but it will be a fiddle but doable. Have you tried rocking the car backwards and forwards I had to do that using Drive/Rev several times before it un jammed. I have also seen one where the cable outer was firmly jammed in the hub (the Dealer solution was New Hub New Actuator cost was enough to write off the car) My solution remove the retaining clip then drive out the cable outer using a long pin punch. It took loads of soaking in penetrating fluid and a big club hammer but it came out 🤣
Replaced the brake shoes replaced Actuator and cable then the Disc/Hub the friend I was doing it for brought an Actuator assembly from Ebay and a set of Pads/Shoes from a local Auto Factor. That was 3 maybe 4 years ago and no problems.
Good Luck
I'd love to see a diagram of that retaining clip, as I think that's going to end up being my solution too, by the sounds of things. It's rear left (curb side) that I'm sure is the problem, haven't looked at the other side. I have tried to rock it, and it doesn't want to budge. I've got the actuator unit loose, so there is more slack on the cables, but that doesn't seem to have made a difference, so I think I need to disconnect the cables from the actuator. I vaguely remember seeing a video of that when I was trying to find out what the problem was, so that's my next hunt
Hi Rhys
Near side cable can be a PITA that side has a 3 or 4 inch long sorry 75 to 100mm left hand thread on it seems to take forever to release from the actuator
If you haven't already take a look at www.realoem.com put the last 7 digits of your Vin into the search box then search the rear axel or brakes sections you should find it and the small exploded drawing will help
Good Luck
