Going Back To Work!!
Hey Dave 👋 I'm back! I'm wondering if the resistor is causing software not to be able to communicate with the ECU because the initial connection is normally established. The issue is when further communication starts then it just falls off and goes dead. Even with INPA, I borrowed a laptop with INPA from a friend that works on BMW's and it's acting strange. INPA sees ignition on all the time once OBD adapter is connected with a light on at all times on the adapter. The light on adapter stays on until getting into any sub menu. For example, E90>Engine>N45/N46. The light goes out and when entering the engine option menu I get an error "Group file : D_MOTOR. IFH-0009: NO RESPONSE FROM CONTROLUNIT. Program will be stopped!" After pressing okay it takes me back go the main menu. Also, when entering the "Functional Jobs" menu, and trying to enter the E90 menu I get the error "Language variants do not match. Malfunction possible!" After pressing okay it takes me to the E90 Menu under functional jobs. When I try to press on identification or vehicle data I get the message "no response from the control unit." I want to note that whenever I enter a new menu the adapter light blinks rapidly for a few seconds like it's showing me some type of data communication is happening then it just stops. I'm wondering if the settings of INPA need to be configured a particular way in order for it to communicate with this BMW or if a module has gone bad. Hmm, maybe I need to test the resistor to make sure it's fine. Maybe just get rid of the resistor all together? I'm not sure what it's purpose is but if all other E90's can operate without it then I'd imagine it'll work without em as well but not gonna jump to any conclusions yet. -
20
Hi Greydog, Thanks for your time checking on the i-Carsoft unit! I will be looking to obtain a copy of the ISTA then! Best, JC -
20
20
Thank you Greydog for your help! Yes, the Maxi unit reprogrammed the RDC but it does not correctly erase the old RDC coding data. That’s why it only work until I stopped the car. Now I know I need another tool to get the job done. 🙂 I will be waiting for your answer! Thanks! -
E90 Cigarette Lighter Fuse(s) Help
Hello all, I have a 2007 328i and the front cigarette lighter socket and ashtray light are not working. The socket in the center console arm rest does work. One fuse I've seen listed on forums is a 20 amp in position #30. On my car marked as 12v accessory. This fuse is not blown. I've seen some posts say fuse #8 is also the 12v accessory socket but on my car that is a 5 amp marked as CD Changer. Is there another fuse for the front 12V socket that anyone is aware of?
