Am I Becoming Sad??
4x4 abs ebv dsc failure
Hi Steven To get the best you will need someone with a BMW capable diagnostic system Obviously BMW but they will be costly as most Dealers now have hourly rates north of £200. A BMW specialist would have the kit and are normally around half the cost of a main Dealer Google the Register of BMW Specialists. Or a good Independent with a top end Snapon, Foxwell or Autologic system there are several others these days Your BMW X5 has around 100 control modules a BMW system will see them all and narrow down the source of the fault a General OBD reader will just see a general code that then takes time to trace Dave -
Also is it best to go to bmw for a diagnosis session or can any mechanic help -
Hi Dave thank u for your reply il look into this thank u -
Damper pulley
TA for that Dave ....i had bring to main dealers yesterday for manf re call ...steering wheel airbag !!...and when i collected it they said they also done mechanical inspection and gave me a 'report sheet '...he pointed out remark on it which is just three words ''damper pulley cracked'' ...his phone rang and he walked off into another part of building ... drove it home the three or so miles but made me bit paranoid about using it now TA again -
Transmission Fault
Morning Mike Welcome to the Forum Bit confused your post says transmission fault yet you ask about key cutting?? Am I missing something as you say the car drives well If it is a new or spare key the simplest way is to contact your main dealer and part with some hard earned Dave
