new to the forum
Inherited an R56? 2009 ONE
Great little cars Stu A neighbour has one and she loves it they do need a good annual service though, seen several that were unreliable due to not being used much and waiting for the service indicator to tell them it needed service? One was 5 years between services? You will also need a good code reader Dave- 1
1996 750i
X1 gearbox service
Morning Cornel Welcome to the Forum Your Gearbox is ZF GA8HP45Z which I believe ZF advise should be serviced every 60 to 100000 km dependent on environment and use (Climate Towing etc) If you feel like teasing your local BMW Dealer service manager ask him if it's sealed for life why do BMW have a gearbox service kit on their parts list 😅 Transfer case is ATC 35L Personally if it is running well and at the low miles you have it isn't an urgent priority. 12 years is a stretch I would look for a good Independent or better a ZF Transmission Specialist if you can't DIY Dave
