Door look problem
650i VANOS failure
Hi everyone, my BMW is due for a VANOS replacement and I’ve found two options with a big price gap: Febi Bilstein (265.19€) - https://onlydrive.pro/parts/camshaft...bilstein-46508 Maxgear (91.29€) - https://onlydrive.pro/parts/gear-spr...axgear-54-1505 Has anyone here used either of these? How do they compare in terms of durability, fitment, and noise after installation? Is the premium for Febi Bilstein worth it, or does Maxgear hold up fine in real-world use? -
BMW X1 valve cover gasket replacement
Hi there all. I recently bought a bmw x1 xdrive 2014. There is smoke entering through the heater vents. Looking online ppl suggested replacing head cover and gasket. Has anyone done it? Is there anyone in Birmingham who can do it? Thank you -
2017 430d LED headlight beam adjustment for continental.
Thanks for reply. It’s similar to what I’ve read elsewhere then. I parked the car facing a wall, not sure if it’s just me, but there’s a slight kick in the beam pattern towards the nearside. Think I’ll chance it. Many other people claim they don’t bother with any beam deflectors. -
Morning Kevin I know that there was an adjustment lever for HID's but I thought I read that LED's had a Flat pattern that cant be adjusted. Does your Local BMW Dealer know more I wonder worth asking As an aside my Brother inlaw has a 5 series Estate and does many miles on the other side of the Channel and I don't recall him doing anything, I will have to ask the question Dave -
Good evening all, looking at going to Belgium next week for a night away. Cant see anything in handbook (online or in I drive) regarding driving on the continent that is relevant. It mentions turning off Auto setting and adjust setting in Idrive “settings - lighting - headlights - headlight adaptation” however mine doesn’t have this option to select/change, not does it have adaptive LED lights, just LED’s. Had a look on the rear of the lamps, nothing obvious to swap over (have seen a lever on other models) Any ideas please? Worst case I’ll sling some beam deflectors on.
