Oil in coolant but not in sump.2003 X5 3.0d sport auto
Thank you Greydog for your help! Yes, the Maxi unit reprogrammed the RDC but it does not correctly erase the old RDC coding data. That’s why it only work until I stopped the car. Now I know I need another tool to get the job done. 🙂 I will be waiting for your answer! Thanks! -
18
Morning JC That's better information A neighbour has i-Carsoft if he is around later today I will have a look At least you now know the cause, will your Maxi unit allow registration ? Dave -
18
I used another ODB reader, I am able to get additional information about the error code. It looks like the used RDC is not properly reprogrammed to work with my car. Do you know if the I-Carsoft 3 or Foxwell 510 is able to reprogram the RDC properly and resolves the errors? Or if the BMW INPA/ISTA the only tool that can fix it? Thanks! -
2011 X3 radio reset
Hi mate, thanks for the reply. If I disconnect the battery will I lose all of my settings? cheers. -
18
Thank you Greydog. I will be looking into these units!
