Best uprated clutch
Hi Dave, Sure, realoem. Part number (steel gasket) is 11628576287. and according to the second drawing (please see attached), this is the EGR Line Gasket. Andrew -
Hi Andrew Are you using www.realoem.com ? The drawing looks like it or is that from the Internet? Is the turbo fitted OEM ? Dave -
Hi Dave, Thanks for your reply! Removing the turbo is not that challenging. The challenge is to find the right gasket.. And here I’m a bit helpless, since no.8 on the drawing does not fit there. Looks like there simply isn’t any gasket.. Andrew -
Morning Anthony Welcome to the Forum Have you checked the Electrical connector and it's sealing ring if they are not seated correctly or the "O" ring is damaged they can leak, a lot. Good Luck Dave -
Morning Andrew Welcome to the Forum Unfortunately the only solution is to strip it all down and then find it is a £0.50p gasket (hopefully) Good Luck Dave
