dash warning light
zeppy
Morning Joe
BRAKE WARNING lamp ! Check brake fluid level
Obvious things to check Handbrake, is it partially on? Does the lamp go out if the engine is started ? What is the warning between the 2 arrows bottom of the dash ? If the Brake fluid is low you have a leak somewhere get it sorted quickly
thanks  to you both for your reply ,have checked fluid level  was slightly down topped it to its correct level light still on, brake pads dont look to bad but will jack car and visually check with wheels removed.
Would the brake pad wear light be yellow and not red?
if the pads are ok, as greydog  said, check the wires. If you short them out... ie connect them, the light should extinguish, telling you it’s the wear sensors.
    2. 12
    3. 12
    4. 5
    5. 5
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
    • Damion earned a badge
      Reacting Well
