warning lights
Speedo display
Morning Peter Welcome to the Forum The only thought I have is you have an Analogue Dash (fixed Clocks) and you have seen cars with Digital Dash panels ? To go the BMW OEM route I think would be expensive to say the least £££ I have read of a company in the UK who have developed Digital Dash retrofit kits called Demonized UK. From what I have read they are very good though I have never seen one or used them may be worth a Google search Nice Motor by the way ENJOY Dave -
Speedo display
I have just purchased a x6m50d which is absolutely lovely. I noticed on few other cars the same as mine that the clocks are a different display? Can I change the look of the clocks. Someone said that you can download an app which will give you different clocks and also make the ambient lighting brighter in the car is this correct. Thank you Leter -
5 series g31 touring
Morning all after having a M135i xdrive for nearly 5 years I decided to have a change and get myself a 520d touring xdrive 2021. Cant compare the two together as both totally different but great cars. -
Recommended body shop in south London for E39
Hi guys. My son has a 2002 E39 530i Sport which needs some remedial work to remove rust off the sills. Can anyone recommend a good body shop in south London, preferably a BMW specialist?
