I have a 2010 320D M sport touring.  I love it to bits but yesterday it started acting up.  When going around right hand bends (tight ish ones like roundabouts) and accelerating the traction control light flashes and the car slows - I'm guessing because the TC kills the power and/or applies the brakes.
I have tried turning off the traction control and it then seems to just misfire.
The really weird thing is it definitely does not do it when turning right or when driving straight ahead.
Can anyone shed any light please?  I would be very grateful for any help.
Thanks
Dean
Update - it has started to do it a little bit in a straight line now, when accelerating at low revs.
Sounds initially like it could be down to tyre size, tread or the fact that you are overcooking it into roundabouts in which case any of these factors could invoke the TC.
But worth checking the diagnostic memory for fault codes or live data with respect to the driveline as there could be a fault with one or more sensors (angle or speed/position sensors)
Thanks for that.  It won't be tyre size as they are correct, and it isn't me overcooking it as it does it at low speed (and in a straight line now as well).
I may have to look at sensors.
I'm also wondering if it is a clogged DPF?
I assume that if it was a blocked DPF the warning lamp would indicate this...unless there is an issue with that?
I'm sure there must be something in the system memory to indicate a malfunction....definitely first place I would check
I'm going to get a reader put on it this weekend.  I'm now thinking it is probably an abs sensor on it's way out
      cruise control switches
    4. 12
      4x4 abs ebv dsc failure
    5. 12
    • Professor80 earned a badge
    • snake2202 earned a badge
    • Julian Pasiut earned a badge
    • Mike Cullwick earned a badge
    • sebhm earned a badge
