EU Headlights reqmt 120 m sport
Speedo display
I have just purchased a x6m50d which is absolutely lovely. I noticed on few other cars the same as mine that the clocks are a different display? Can I change the look of the clocks. Someone said that you can download an app which will give you different clocks and also make the ambient lighting brighter in the car is this correct. Thank you Leter -
5 series g31 touring
Morning all after having a M135i xdrive for nearly 5 years I decided to have a change and get myself a 520d touring xdrive 2021. Cant compare the two together as both totally different but great cars. -
Recommended body shop in south London for E39
Hi guys. My son has a 2002 E39 530i Sport which needs some remedial work to remove rust off the sills. Can anyone recommend a good body shop in south London, preferably a BMW specialist? -
2011 bmw 328ix drive shaking at 45 miles ahour and at other
Hi Brandon. first things first. Change the wheel for the spare.. if it stops, it’s the wheel. Next, check the wheel alignment. Then check for uneven wear across the tyre. You might have bent a suspension component. Check to see if a spring has broken?
