Possible head gasket issue?
4x4 abs ebv dsc failure
Morning Steven Really ? your screen shot doesn't show any VTG Fault or is it a new one ? Or is it a different scan ? You will need to either get them checked and repaired other wise the K-can bus faults will never be cleared and they will prevent some others being cleared. My course of action would be first repair the K-can Bus and clear down all the K-can Bus faults either using a Scan tool like your original screen shots or simply disconnect the Battery for 30mins (a Dealer Trick) Once that is done re-scan and see what faults show. Many folks have carried out costly replacement/repairs due to treating a symptom not the actual cause. Transfer Case damage/faults are normally tyre related or the VTG oil needs replacing Seems you are making progress though 😁 Dave -
Hi. Having read so many articles from BM convertible owners, it is appalling that BMW fails to recognise and this fault through a recall? Do you know where the water enters the sills/ boot area? Can the point of entry be identified? Does the sill fill up before entering the motors etc? I ask because I noticed water escaping from the rear , near side sill area after a car wash and therefore want to solve the issue before it reaches the stage of such expense that you have had. Any help ideas welcome. -
5
Inherited an R56? 2009 ONE
Gave the car to my mate who gratefully took it for his young family. he took it to his local garage and turns out the camshaft timing sensor was clogged up and misreading. I had changed the inlet and outlet cam sensors but not the camshaft sensor. an engine flush and clean, new oil and spark plugs, a good service and it’s off like a scalded cat! Cost wise it was about £300 to sort. happy days!- 1
8
Thank u so much for your time Dave I managed to get someone to plug in with bmw diagnostic and they said they narrowed it down to the transfer control case module il check these cables thou aswel -
5
Damper pulley
Got to bring it to mechanic i use all the time ....showed him 'report' ...he just started laughing ...he has seen same thing twice already in last 6/9 months with other bmw owners coming from SAME main dealer !!!!!!! guessing they must have surplus damper pulley stock ......- 1
