3 Bleeps???
Hi all,every so often im getting 3 bleeps coming from the dash,anyone know what this warning is for please? there are no warning lights on the dash.Ive an E36 328i cab,thanks all
If you have no warnings coming up on the dash I would imagine it's the temp sensor telling you it is cold outside. My 7 moans every morning this time of year
Daz
ah could well be Daz
I'll check that out too Steve
thanks lads
also, do you have an afermarket stereo, my pinoneer head unit beeps 3 times when i take the key out of the ignition to remind me to remove the face plate. also the temp sensor, which beeps 3 times when the out side temp drops to 3 degrees or below :P
Its below 3 degrees outside!
Temp sensor mate
What was the problem in the end?
Temp Sensor is what I believe would be causing the beeps mate
Do you have a coffee maker in the boot?
never found what it was,just stopped of its own accord,strange one that :wacko:
  • 1 year later...
Hi guys I too hear 3 bleeps now and again will have to note when and see if outside temp is below 3 degrees. If not presume aftermarket radio fitted. Cheers.
would agree with the temp sensor as it is normally 3c or below at this time of year'
however there is a small chance of it being a warning & its not illuminating on the dash but its sorted for you now, great -_-
Still having 3 bleepitis !! Not temp sensor must be aftermarket radio. What does the memo button do ?
are the bleeps when driving or when you switch on the car ?
its about to blow! - - - get to tha chopper! :blink:
