New To The 728I (2000 Model) - A Few Questions...
A paddling pool in the rear of my 08 reg 635d Convertible !!
Hi Paul. I have sent you a message on the system messaging service. -
8
Yes 650i convertible, my error by the way I though I read 325Ci. mine and yours should be near enough identical. Here are the images I mentioned. pic 1 - back corner of the storage area - 1 each side pic 2 - literally adjacent to the rear strut pillar Pic 3 - rear corner nearest to the rear of the vehicle right side Pic 4 - as above left side Pic 5 - same as pic 1 but other side - this location is tucked right back immediately under the folding brackets. I am not aware of any other drains under that protective cover as that does not lift up. There have been times I have had several inches of water in there sloshing about but none has actually entered the passenger compartment. As I said I do look to blow through these drains on a regular basis. Hope this helps. I have had water getting into the boot area carpet, this rides under that black plastic cover you can see in pics 3/4. and drips into the boot. BTW Im in Formby and more than happy to meet and talk it through if that helps. The whole system of the softtop seal onto the car body is not watertight hence the need for drains but these have to be kept clear otherwise water does build up and can get into the boot area as noted above. -
Brake Pipe Failure 650i
will do...... as you can see from the photo it is the area under the fuse box to the right side of engine compartment looking from the front. Hope the experience has value to someone out there.. The previous experience I mentioned of an inaccessible brake line fail was on an X5 not a 5 series. -
Wow lucky boy that could have had some serious consequences !! Do the Lottery quick 😁 Great pics and information Paul as BMW tend to stick to patterns with layout I think I will check the E70 tomorrow Dave
