Lights On The Dash Board Flashing On And Off Solution
Luggage 'Lashing Eyes' in boot
Morning Dave Thanks so much for the helpful advice. I've searched that site - very useful. Unfortunately the position and type of the front mounting has changed since the F45 model. Why BMW structured their software search engines in this way surprises me. Yes if you use a specific VIN then you should get the part you require, but it doesn't cope with searches like mine. I suppose like all things it comes down to cost. A more universal search engine would require more complex programming and data management. Such is life. To be fair to the Main Dealers and BMW UK, they were all apologetic, and I think a little embarassed that the system wouldn't let them help me. Ian -
Low Oil Pressure warning
Morning Jack Welcome to the Forum Not good news and although you aren't seeing visible signs, low oil pressure will over time start to reduce oil feed to probably the upper parts of the engine. As your garage found evidence of chain guide wear/brake up it needs investigation. I would start with simple stuff Check/change the Oil Pressure switch just in case it is that simple. The next bit involves dropping the sump to check the Oil Pick up pipe (I have seen one with a split "O" ring seal that gave similar symptoms to yours (flickering oi light at tick over) If the sump is off clean it out and I would change the oil pump tensioner and guide. Hope this is helpful Dave -
Buying an X1.
Have shortlisted the X1 to replace my Mazda CX5. Seems to tick all the boxes but a few questions. Looking at the updated 23 model . Can you get a spare wheel for the X1 and can it be stowed away out of sight. What MPG can i realistically exxpect from the 1.5 s drive engine? Can you fit an adult bke in the back with seats down? What is the annual car tax on an X1 valued new at under £40k Thanks in anticipation. Lots of useful information on this forum. I -
Morning Ian Welcome to the Forum BMW had a Parts Number website and a Technical Information website which for folks like us and independent Garages was a great help as we could find correct part numbers and see what was involved in fitting them. Then in 2019 BMW decided to take down the Technical Information Site and make it Dealer access only the parts website they haven't taken down but the also haven't updated it since 2019 ??? Hey Ho Having said that www.realoem.com is still a massive help I just had a quick look (manual search) and have a part number 51477271174. You can check for yourself Google realoem then either try your Vin in the search box (may not be recognised as the site stops at 2019) or as I did search manually I used F45 Active tourer and searched the Trim section if you double click the Part number you will see a list of other models that it fits or you could use. Then as BMW have been so helpful ?? Look for the best price, don't ignore the local Dealer they are sometimes competitive on price I hope this helps Dave -
Hello everyone, Recently changed my X1 xDrive 2.0 Sport for an Active Tourer 220i M Sport, which unfortunately has no luggage Lashing Eyes. I think they may be fitted to the Luxury Trim version.My X1 did have them. When I approached BMW UK, they informed me that to look up the appropriate Part Numbers for ordering (so I can have them retrofitted) they need a VIN. When I supplied my VIN, that didn't work because on my model, the parts weren't factory fitted. There are holes in the boot trim and bodywork, in the correct places, but they are currently filled with plastic blanking inserts. Anyone out there any suggestions , or if you've got them fitted on your model, could you email me your VIN so I could use it in attempt to source the part numbers. If you're worried about disclosing your VIN, don't be, remember its visible through your windscreen whenever you park your car. If you can help it'll be much appreciated.
