Air Bag Warning Light Stays On My Bmw 1999 740I! Any Ideas Welcome!
Hiya, My Air Bags Warning Light Goes Of For 20 Seconds On Startup, Then Comes Back On Again! I Hear It Is A Common Fault With My Model 740i 4.4 V8 & An Easy Cheap Fix!!
Any Ideas Welcome!!!
Cheers, Mike.
post-2681-0-05483900-1327346244_thumb.jp
Passenger seat Occupancy Sensor ! ALL BMW's suffer from this issue.
Expensive to fix and a ball-ache to do, but you can get a cheap bypass unit from Ebay... ;)
Cheers Jack, will have a look!
All the best, Mike.
I had this fault on my e39, thought it was passenger occu sensor but ended up being seatbelt pretensioner. my advice is get a diognostic plugin and see what it says.
good luck
Cheers Mike, Will do! Great Motor, but these silly sensors are a "Pain In The #####"
All the Best, Mike.J.K.
  • 11 months later...
  • 3 months later...
Hello to you All, anybody know an easy way to change Rear shocker on my 1999 740i, ??
i nedd all the help I can get!!
Cheers, Mike.
Shocker?? not sure on the her..but should be a very simple job...
Hiya Gav, thats what I thought! Check it out buddy & get back to me, sounds like a nightmare!!!!
Cheers, Mike.
Hiya All, just had the shocker changed by KWIK FIT for £135. that's including towin & towout + wheel alignment. "BARGAIN"
Benhams of Wolverhampton (BMW DEALER) Wanted £480. trade!
ChecK the work involved!! Click the Link Below!!!
http://www.bimmerboard.com/forums/posts/590961
Hiya Gav, just had the shocker changed by KWIK FIT for £135. that's including towin & towout + wheel alignment. "BARGAIN"
http://www.bimmerboa...ms/posts/590961
