Hello
heath85
Oh yes, full AC Schnitzer treatment. Just sorting some pics I took a couple of months ago as its in the spray shop at the mo having any slight marks that I've picked up recently removed. How much do you guys know about window seals?
Cheers pal. I'll tell you what it is, the rear windscreen and two rear vent windows seals look very perished. I've been told by somebody that it's not the seals that you can see but just plastic or rubber fillers to lose the gap from the body work to the window? Do you know how true this is?
It was the seals, and the rubber compound used... They failed to maintain their shape, causing seepage and internal dampness... This was corrected as you may have read...
There is a fix - Knife along the lower edge of the seal and fill with sealant or screen-bond - both flexible, this will push-out the seals to re-create their purpose...
Or better still, replace them with later model seals...
My quick-fix is cheaper, though... !!!
      Steering wheel replacement
      F30 A-pillar install
    5. 6
      Front windscreen washers
    • Conmil earned a badge
    • Loulou earned a badge
    • Robbawdie earned a badge
