Do I Have Heated Seats?
Can anyone recommend somewhere for testing and fixing an ECU around the Warminster Trowbridge area please Don't mind posting if needed -
E64 oil filter holder life
Finally, I did take it the damaged part into BMW but heard nothing........ -
Hi Dave, that is a possibility, over tightening, but I understand the material used does have weaknesses especially when it is cold. I was lucky, the day before Im doing 85 on the motorway, no issue, the next day on start up, part failed and luckily no heat got into the engine before I realised. Hence the question. But good to know there is no actual recommendation to change at intervals. Appreciate the research.
