Help With Headunit Connector
suspension / service
Hello all been few years since on here with my x5 4.8is, back now with 2015 f15 30d had for 5years been a great vehicle ,h&r springs on front loweringkit on back front feeling like juddering at low speeds dosent feel tight do I refresh front suspension also I've not changed diff or gearbox oil what's best advice ,I do like to attempt jobs myself cheers j -
Diesel Engine Running Rough
Hi Paul Welcome to the Forum You need a good Independent Garage but one with BMW capable diagnostics or a BMW Specialist who will have the kit and knowledge There is a Register of BMW Specialists which you could Google which should give you some local contacts Poor servicing is sadly quite common due to (a) many modern cars can have the service indicator reset without work (b) extended service intervals due to modern oils some up to 30k are just nuts. That means a car with 70k may only have had 2 services ?? The only real evidence is a good old stamped book and a wedge of receipts Hope this helps Dave -
Hi Paul, sorry. Got your name wrong! 😑 welcome and sorry to hear of the issues. surely there are new Indy’s in Leeds with software. if you can get across to hull, there is a good garage called bm tech near the deep. they are good and all ex bmw technicians. im based between hull and York. -
Hi, looking for advice and/or recommendations. I have a 2016 2 Ltr Diesel 2 Series Active Tourer 218d. Bought the car thinking it had a FSH, at 70k miles now got 75k ish. Looks like it hadn't been properly serviced for about 20k miles. After running it for 8 months the engine started to run rough and when my regular garage took a look the filter was on the cusp of falling to bits and the oil thick with not much of it. Up until that point it seemed to run ok. My regular garage don't do engine diagnostics, just regular servicing. It still runs, but rough. Its been suggested that it could be as simple as the timing chain is stretched and thus a replacement and having it timed up could fix it, but it also could be that more damage has been done. I'm struggling to find someone/where to diagnose and repair, I'm based in Leeds. Can anyone share any solid recommendations in the locality that could diagnose and repair? Or maybe I'm better just selling as spares or repair?? Any help greatly appreciated, just want to get it sorted or sold and move on. Cheers - Paul
