E32, 735Ise, 1988 sensible offers
Morning Anthony Welcome to the Forum Have you checked the Electrical connector and it's sealing ring if they are not seated correctly or the "O" ring is damaged they can leak, a lot. Good Luck Dave -
Morning Andrew Welcome to the Forum Unfortunately the only solution is to strip it all down and then find it is a £0.50p gasket (hopefully) Good Luck Dave -
DPF Cleaning fluid
Hi everyone, I’ve noticed an oil leak coming from the turbine outlet flange area on my BMW 320d xDrive G21 (2019, B47 engine). The oil seems to be coming from the joint between the turbocharger and the downpipe. Has anyone had a similar experience? Any help or experience with a similar issue would be really appreciated. Thanks in advance!
