Common Problems With Your E46
G4VHD
If there are no obvious oil leaks (oil on the floor), have a smell at the fumes at the tail-pipe you will notice a difference with burnt fuel vs burnt oil !! This could mean excessive wear at the valve-stem seals, engine breather-pipe issues, head gasket ... Worst case scenario would be piston rings (oil control ring)...
Best to start with the easy stuff and have a real good look around the engine, top to bottom and check all mating gaskets and oil seals for leaks... Then maybe remove and possibly clean out the engine breather hoses...
The morning after it has been used try removing the spark-plugs and notice their condition (keep each one with it's corresponding cylinder)...
To be honest, if it is burning oil excessively you would probably be getting Fault Codes !
Thanks for the advice Dabsy, I'll let you know how I get on
2002 Pre-face lift E46 Coupe 318 (N42B20) 2.0ltr valvetronic engine. Recently just past 120,000 miles.
Common issues that I have had were:-
Control Arm Bushes - Replaced with Lemforder units
Rear Coil Springs - Replaced with Boge HD Springs
Rusty Front Wings - Bought two wings from a scrapped E46 Coupe from Fab Direct (recommended BMW breakers in the Forest of Dean)
Sagging Door Seal Liners - sorted (I did not buy new door seals from BMW because they wanted £250.00 per door seal!!)
Flaking Interior (Plasticised Trim) - removed the plasticised material and will be sourcing replacement trim gear surround & inner door handles
Oil Filter Housing Gasket Perished & Leaking - Replaced with OEM gasket
Air Conditioning (Turned out to be a faulty temp sensor behind the center of the dash)
Final Stage Resistor (Still need to replace as the fan blower is at erratic speeds)
Specific to my engine were:-
Leaking Vacuum Pump
Chain Tensioner - (Modified Version Available from BMW)
Overall, I love this E46 Coupe! The E46 is by far the best looking of the 3 series although I am a big fan of them all.
Hi guys I have just bought a 320ci convertible and I have tried have a lil play but when it starts to go side ways it dies and I tried doing a stand still burn to see what the problem was and the wheels didn't even move.
Would be nice to here others opinions
Thanks
Had a recent service & report came back clean. Just One thing was front pads low which I knew. Don't know if it was a sales pitch, but Sytner rep said I have a good 2nd hand One that's been looked after (er - that's why I brought it) & then showed me a fault list on an 08MY which was Three A4 long!
However even before my service, I'm getting a slight judder when in low revs between all gears. I've heard from a few it may be the EGR Valve...
Is this the best place to start or could it be something more obvious? Thanks!!
320i SE Saloon 2001 x
112,000 miles owned for last 2 years and covered 30,000 miles.
Nsf lower suspension arm
NSF & OSF susp arm bushes
Airflow masterpipe split
Radiator sidetank
Central locking a bit temperamental as is front passenger window
High oil consumption, approx 500 miles to a litre
Aroung 30mpg overall
May look like a lot of problems but the car has never let me down and generally runs well
Since August I've had a new cam sensor - symptom was rough running when warm
As it is intermittent I would have to say that it could be any of these...
Tired fob battery...
Wiring connection (worse when cold)...
Receiver...
Module, either faulty or connection (as above)...
HTH... Could be allsorts matey :unsure:
Receiver...
As always thanks for the advice Dabsy.
Is there a way of unlocking the other doors manually?
Yes, pull the inside lever twice if the console button doesn't work !!
If its a four-door and the rears won't unlock manually, then the child locks are on also :huh:, door cards off and push the lock-rod upwards...
Also, using the key in the drivers-door has other functions too, like dead-locking and "combination" lock/unlock...
I remember having to turn my key in the door clockwise 3 times and the same anticlockwise to override the central locking on my E34 some years back !!... Or was it the other way round :o
Heard a rattle coming from exhaust & noticed the bracket from the main frame had come adrift. Looked it up & found its a common warranty fault until 2009. Attached link shows what's required with Part Number.
http://www.bimmerforums.co.uk/forum/threads/24785-2005-E46-320d-Touring-Rear-Exhaust-Hanger?highlight=broken+exhaust+hanger
Receiver...
Hi Dabsy
Thanks, I've had the control unit replaced (with a second hand one) which seems to have done the job and not too expensive
Thanks
Ocky
318i SE, 2001, 73,000 miles
Indicators flash at double speed for first few miles when car started up, either left or right. Was told its a common fault with instrument panel. Anyone else had the same problem?
Adam.
    3. 12
    4. 12
    5. 12
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
