How Much Is It Worth?
Damper pulley
TA for that Dave ....i had bring to main dealers yesterday for manf re call ...steering wheel airbag !!...and when i collected it they said they also done mechanical inspection and gave me a 'report sheet '...he pointed out remark on it which is just three words ''damper pulley cracked'' ...his phone rang and he walked off into another part of building ... drove it home the three or so miles but made me bit paranoid about using it now TA again -
Transmission Fault
Morning Mike Welcome to the Forum Bit confused your post says transmission fault yet you ask about key cutting?? Am I missing something as you say the car drives well If it is a new or spare key the simplest way is to contact your main dealer and part with some hard earned Dave -
4x4 abs ebv dsc failure
Morning Steven First I take it you are working from lights on the dash you really do need a Diagnostic session to be sure of the Fault cause. From your description the fault could be the Junction Box/FRM (footwell control module) it controls many functions. You will need to change it if you can get the same part number it will be straight forward but you will need to match the mileage so note it before starting or you will get a tamper dot on the dash Dave -
X3 - YOM 2013 -Coolant change
Morning Stewart There is a drain plug in the bottom of the rad or simply pop off the bottom hose. The hoses have an "O" ring seal held by a spring clip, if you prize up the spring clip you can wiggle the hose off have a big tub/bowl to catch the coolant Dave -
Damper pulley
Morning Frank Who told you that ? The Damper pulley is made of steel as is the inner boss the two parts are held together by a vulcanised rubber core it is probably the rubber which is showing cracks, how did they see it? If you look down from the top of the engine and the pulley is wobbling when the engine is running I would consider changing it (if you do then it is worth changing Belts Tension and Guide pulleys as well) If the pulley is steady then I wouldn't worry to much Hope this helps Dave
