Shes Insured, Passed Her Mot And Now Has Road Tax!
Rear knocking
Morning Paul Welcome to the Forum I would check the rear brake back plate I have seen this twice now both time s on E70's of the 2007/8 period To change it is a heap of work (hub dismantled) as the back plate is sandwiched between the brake shoe support plate and the Suspension hub I have cheated and once the disc is off remove the bolts holding the brake back plate and shoe support so it is all loose. Then I managed to change one by cutting it in half to get it off the new one I cut out the section where the Calliper sits then sliding it into place. The Brake shoe support plate and Back Plate are held in place by 4 m6 hex bolts. Still a faff but doable Dave PS. When your in there check all the area in case it is a heat shield loos or something on the driveshaft -
Rear knocking
Hi all, Been reading this forum for quite a while but being lucky enough to not have had any serious issues with my old x5, I've never had cause to post a question. Being new to the forum, not quite sure if I'm posting in the correct place, and I've already searched the topics for my issue but without success. So here goes, I hope someone can help. I have a 2007 x5 3.0 diesel, which we use to tow our touring van. On the way back from our last short holiday, it developed an intermittent speed related knocking which could be heard from the rear of the car. There was no specific trigger, sometimes it happened when pulling off, other times it happened on overrun. Once in a while it would just start while at a constant speed, sometimes I could stop it by lifting off the accelerator, sometimes by speeding up. It did seem to happen more at lower revs when pulling away or uphill, but not always. I spent most if the journey convinced it was coming from the caravan, but having now left the van back in storage the knock is still present although not so frequent so it seems to have been made worse with the extra weight of the van hanging off the back. It's definitely speed related and its frequency increases in time with wheel rotation. There's no gentle build up, it comes on and stays at the same loudness regardless of how fast it is although it may be a little louder on left hand bends when more weight sits on the drivers side rear wheel. There's no other grinding or rumbling, and the knock is a very clean metallic sound, like hitting a tin can with a stick. I'm not thinking suspension as it isn't brought on by road bumps or potholes, so my suspicion is leaning towards the wheel bearing/ rear axle area but, in truth, I have no clue. If anyone can throw some light on the most likely cause, at least it will give me a starting point. Thanks in advance for any help or suggestions. -
5
Luggage 'Lashing Eyes' in boot
Morning Ian In realoem double click the part number and it should show a list of all models that it was used in/on It will also show any alternate part numbers Fingers crossed Dave -
5
Hi Dave, I've now spent some time checking out realoem.com and the lashing eyes on older active tourers and X1s seem to be identical. I think the variation in the front lashing eyes only seems to occur if a high (i.e. from the top of the rear seats to the roof) luggage net is used. So I'm going to order just 2 eyes and see if they will work. Your Part number does occur on various other models. I'll let you know if I'm successful, in due course. Once again thanks for the help. -
Buying an X1.
Hi Bob, I when I had my 2018 X1 Sport I was able to fit my adult eletric bike in the back, but I had to remove the front wheel. I understand the newer X1s are a smidgen larger, but I don't think the boot dimensions have increased significantly. Regarding the 1.5 3 pot engine, that's what powers my 220i Active Tourer sDrive (although it's a mild hybrid). During the last month I've covered some 500miles, at lot of which was motorway and dual carriageway, and my MPG (according to the on-board computer) is 49.2. Whilst your X1 is larger I'm lugging around a battery but getting the advantage of slight regen. The DVLC website has info regarding the roadtax you'll pay. My X1 was purely petrol and I did have a spare wheel. Provided you are not looking at a hybrid, then a spare wheel should be possible under the floor. I hope this helps Ian
