Sorry TOMO, I didnt mean it like that, It was ment to be a question in reply to your question sorry.
Cant you put a pin in the hole where the water comes out and adjust it that way?
Sorry if I came across patronising.
no problem mate. The jet is hidden in the plastic cover and i cant see inside,thought the cover might come of but didnt want to start pulling and crack any thing.
Ill have a look on mine tomorrow, not sure if its the same as yours though. I'll take some pics.
Thanks,look forward to hearing from you.
No probs mate, I got a E46 03 plate, so got a chance they could be the same.
Ill post up around this time tomorrow.
Right done some reading, and there not adjustable!!!
Check for lime scale build up,
Take the pipe off the back of the jet and with water in your mouth, blow water down them backwards.
Thats all I got mate..............
thanks for taking the time to look into it,will give it a go at the weekend as its too dark when i finish work,cheers.
      4x4 abs ebv dsc failure
      Damper pulley
      Transmission Fault
    5. 3
    • Pipthechippie earned a badge
    • stehay123 earned a badge
    • Cain59 earned a badge
    • frankman earned a badge
    • ValdeFortis earned a badge
