Firstly, thanx for the warm welcome guys...
Issues with my late1996 728i -
My headlamps come on by ignition to set themselves, turn off and come back on when they feel the urge (even with switch off) !!
Heater barely works until after about 4 or 5 miles !
Rev counter struggles, if it moves at all !!
Apart from the above it is a fantastic car/rocket - hahaha
DAZ
hmmm a few probs then!
heater could be the thermostat?
rev counter could be dodgy sensor, poss the clocks themselves? id say its a sensor at a guess.
lights, maybe the switch is faulty?
a diagnostic check should reveal any probs in the system.
i done mine a few months ago, cost me £65 if i remember right, but that was the housing aswell so on its own it should be alot less. easy enough to change to
.... And another niggle is that I can lower the osr window but not raise it, but it will raise using key fob !!!
Can I set things using the dash test system? Or will it be a laptop jobby?
DAZ
      Brakes applying themselves
    4. 9
    5. 9
    • darcus30 earned a badge
    • Gazdoug earned a badge
    • Julian P earned a badge
    • bmwfish earned a badge
