E90 Splitter Spoiler from EBAY
Can anyone advise on best place to obtain new full pile replacement mats for my E64. Just had a bad experience on ebay so they are going back, totally missold. Just need a nice set in black with the velcro pads already fitted as per BMW spec. -
Wireless charging?
S24 Ultra is QI charging compatible (which I belive the factory fitted OEM charging tray is) I have a QI wireless charger in the house for it. Like I say I get a Blue LED when I put the phone it the tray, but doesn't seem to want to charge, will borrow a friend's phone and try that. Thanks -
E92 Preventative measures
Hi Guys I have an E92 330d with 150k on I’m having the swirl flaps deleted and it’s booked in for a gearbox service next month, other than regular servicing is there anything else I should be doing (preventative or otherwise) thanks Daz. -
5
650i crank no start
Morning Hans If the fault is EWS or CAS related I think you need to read up on resetting/resyncing the Key/EWS/CAS or if your diagnostics are up to it re-programming them. As you have a donor nearby maybe take the EWS and Keys ? Fingers crossed it is fairly simple and a reset works Dave
