First BMW at 44 - such wasted time! Very happy, but couple of questions.
Top Man thanks for the close out to the post- eu spec
- contact failure
(and 2 more)
Engine cut-out on idle.
Tapping
Hi Daniel Welcome to the Forum Your tapping noise could be a number of things from a sticking hydraulic lifter to a failing chain tensioner. What is the service history ? Extended service intervals can cause issues get the Chain tensioner checked/changed would be a starting point Dave -
9
- contact failure
(and 2 more)
Tapping
Hello after some advice 2012 petrol m getting a tapping noise at cold start up goes after a couple of minutes done 71000 is this normal
