97 e36 rollbars reset ?
phoenix
Welcome
I aint got a clue how to do it personaly, but I found this
step 1 - pull up headrest - it goes up 2 inches
step 2 - insert screwdriver in slot in the trapezoid shaped cover that is exposed under the headrest when its extended
step 3 - once cover is removed, you see 2 aluminium levers in the exposed area. The front one is the rollbar release leverl.
step 4 - Position yourself in your backseat. While pressing FORWARD (toward the front of car) on the front rollbar release lever, simultaneously push down on the rollbar. This takes just a little effort, since the rollbar is springloaded. don't worry about crushed fingers as the rollbar straddles your hand's position on the lever. Push the rollbar down until you hear it click into place.
Step 5 - replace the plastic coverplate, front tabs first, then rear
Show us a pic before you reset it, never heard of this let alone seen it
Welcome
managed to reset rollbarrs using bmw tool
lift headrest, there are 2 small cutots on rhs of each rollbar the tool slides down these and releases catch , push down rollbar till it re-latches, while removeing tool, note tool has a lug on it this needs to be at the top. bmw tool was aprox £32 if i had known dimensions of it i could have made one at work
      Amplifier replacement.
      Front windscreen washers
    5. 3
      wheel fitment
    • Danny428F33 earned a badge
    • damiansteel earned a badge
    • Loulou earned a badge
    • hermit earned a badge
    • Robbawdie earned a badge
