how to remove the headunit in a bmw 318i
Seat Bolster Wear?
As with all modern car seats the drivers side bolster has started to wear, the leather one in mine has just started to loose the leather shine and the stitching has fluffed. Anyone used any really good product to help delay the inevitable, I've currently just started applying a bit of Meguiar's Gold Class Rich Leather 3in1 Leather Cleaner & Protectant. Was thinking of trying a bit of dubbin. -
15
Agreed, I was also eyeing up MICHELIN PRIMACY 4's, although BMW fitted new tyres when I bought the car, so I have a while to go until changing (hopefully). -
Front windscreen washers
Help needed please with front windscreen washers. They only seem to work when the engine is not running, I open the bonnet to test then & they work fine, close the bonnet & they work fine, drive off & they might squirt once or twice. I've changed the pump, the pipe & the washers. Any ideas please Thanks -
Knocking noise top of engine.
Morning Ross I would start by checking that all injectors are OK, seated properly and fixed down at the correct torque. If there are no injector or glow plug issues then the valve train needs investigation could be a lifter sticking or a Vanos issue. Dave- 1
