Morning Hans
If the fault is EWS or CAS related I think you need to read up on resetting/resyncing the Key/EWS/CAS or if your diagnostics are up to it re-programming them. As you have a donor nearby maybe take the EWS and Keys ?
Fingers crossed it is fairly simple and a reset works
Morning Rich
First is the wireless charger OEM or aftermarket ? Second is your phone compatible with the charger? (it seems not)
I only know 1 person (our son inlaw) who uses wireless charging he is an Apple user and the system in his 3 series is OEM he has no issues
Morning Shawn
Lucky son 😁
Even Dealers technicians (they don't call them mechanics anymore so they can charge more 🤣) can be clumsy rock apes at times.
With the Xdrive cars correct sized tyres are essential to protect the Xdrive transfer case, diffs etc
Hope your boy appreciates his car
Morning Rich
Enjoy your Beemer
If I am right your model was in a change over period so could be G21 or F31. If you look at www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model. The site is a BMW parts site as used by Dealers so really useful if buying parts and seeing where they fit.
Again you can use a BMW Vin Decoder to check your cars original build sheet.
Hope this is helpful
I’m new to the forum as well as to BMW automobiles in general. I just purchased a 2013 BMW 320i Xdrive with just under 57,000 miles for my son as his first car. Looking at service records the timing chain, valve cover gasket, oil pan gasket, brakes, and rotors were replaced around 45,000 miles. Are there any common issues these cars tend to have that I need to be aware of? The only thing I’ve found is one of the reverse light housings is broken on the side next to the tail light. A common problem if you don’t remove the housing correctly from what I’ve read. Feel free to give me any advice or info I may need to know.
