F21 118d Lci engine issue
Hi all,
I’ve owned my F21 118d for almost 5 months now. Since I’ve got it, it’s been making a squealing noise whenever I floor it. This only happens when above 2.5-3k revs and if I’m flooring it and in gear / driving. Had a garage check for a boost leak and all my pulleys / tensioners but they are all fine. About 3 months ago, whenever I turn the car off and turn it back on shortly after (engine still warm) it makes a whining noise that seems to come from the turbo - see attached video.
As the squealing sound sounds like it is some sort of bearing spinning, I’m wondering if the 2 issues are related. My turbo also started whining a bit louder and sounding different last night, which is why I think it may be the turbo.
I’m wondering if anyone had had this issue before with theirs? For reference, I believe the engine code is B47D2U0U?
I have it booked into the garage tomorrow so will be asking them to check the turbo before anything else unless anyone gives me a better idea.
Solved by jvmes
On 3/30/2026 at 7:08 AM, Greydog said:
Morning James
If you are positive it isn't Belts Pulley's or Tensioners check all Vacuum Lines to the Turbo plus the Intercooler Hoses I had a Volvo T5 that had a split intercooler hose that made a similar noise
Good Luck
Hi Dave,
Thanks for the comment, turns out it was my turbo and the turbo shaft? broke while the garage was test driving 😅 looks like I need a new turbo.
Thank you!
James
  • 5 months later...
  • Solution
Not sure if anyone will see this, but noise I was getting was my turbo. It ended up blowing up as I got to the garage 😅
Ended up needing the timing chain and my clutch / flywheel doing also… fun times!
Theme by IPSFocus
Bimmer Owners Club Powered by Invision Community
