F20 pre LCI EDC removal
Has anyone with an F20 fitted with EDC swapped the factory dampers for passive manually adjustable suspension? Does it bring a dash light on? Can this be coded out? Any help greatly appreciated.
Hi Simon
Never tried so can't confirm but I would assume that once unplugged the Dampers will trigger a warning and as it's suspension related may even cause limp mode/restricted performance. It follows that the car needs to know the system is not active so you may need the help of someone with ISTA-P
Good Luck
