2017 bmw x5 35i crank no start
Hello guys I have a 2017 bmw x5 with a couple codes I have attached them to this post
135808 Valvetronic Servomotor, Position Sensors, Electrical:
Malfunction Permanent
194604 Diagnostic Module For Tank Leaks (NVLD), Electrical: Line
Disconnection
Permanent
164020 Intake Camshaft Sensor, Electric: Short Circuit To B+ Intermittent
108A10 PhausibiAir Temperature Sensor, Electrical: Signal Not Intermittent
164021 Intake Camshaft Sensor, Electric: Short Circuit To Ground Intermitten
Where I am puzzled is is the crank no start from the sensors or from the Valvetronic motor ? I’d like to know what you guys think of these codes and let me know what you think
BMW_X5xDrive35i_5UXKR0C34H0V75376_DTC_20260206184634.pdf
Morning Denzell
Yes the permanent faults could well give no start condition. I would start with a continuity check of the engine bay loom and connectors, if they check out OK then test the sensors with permanent faults (you should find test parameters online) That should give you a clear picture of where the issue is, the short circuit faults need investigation and repair (loom/connectors)
I would also check the ECU (DME) connector pins for any signs of degrading/moisture/corrosion check fuel rail pressure and sensor also
Good Hunting
