E63 2003 - 735i
Hello
Our son has a 735i in Greece - does anyone know where we might find a plan with part number for the rear window sun blind please?
Two very small plastic 'wheels' have had enough and fallen apart....whatever way I look at it I know im going to end up sourcing them, taking them out with us and having the probably very fiddly job of replacing them
Solved by GAH
Hi Gary
Take a look at www.realoem.com put the last 7 digits of the Vin into the search box and it will call up your model. Then search the relevant sections (Trim I would think) you should see a small exploded drawing (which helps with fitting) with a list of part numbers, once you have the Part Number the internet or BMW specialist recyclers should track down a source.
Hope this helps
  • Solution
Hello again Dave
Thanks for that - sonny boy reckons his independent BMW guy (who he bought the car from and has done all servicing and other minor repairs) will be able to come up with second hand parts for the curtain AND supply a used speedo.....LED melted due age and heat - his BMW is black - just what you need our there ;)....
Given the age of the car, and more to the point it's rarity in Greece he might struggle!
Theme by IPSFocus
Bimmer Owners Club Powered by Invision Community
