Oil leak from feed tube to top turbo
Hi Graham
The issue is most likely the sealing washers on the fitting. Bit of a faff getting to it but the oil feed pipes rarely give problems unless some heavy handed so and so has damaged them so changing the sealing washers should fix your problem
