Hi
Looking for some help, I have a BMW 116D 62 plate, (re chipped to 120D).
We are having issues with the centre console, only displayed the BMW logo, no menu, radio options, mode changes, phone, unable to play CD's etc. we are not able to change anything.
The radio also comes on but doesn't display then channels for a period of around 5 mins stuck on one station, then turns off for about 24 secs.
I've tried a couple of things which I found on Google but have not resolved the issue.
Any help would be appreciated.
Many thanks
Morning Dave
The system in your car is made up from 3 main parts (1) the Display Screen (2) The Rotary control on the Centre Console (3) The CiC unit (behind the dash) these are linked normally through the FRM (Footwell Module) A Diagnostic scan will show where the issue is
As the Display is working logic points towards the other two. You will need the help of someone who has a BMW capable Diagnostic package to (a) confirm which one (b) make sure any replacement is coded to the car and works correctly
If the Rotary Controller is OK and the issue is with the CiC you have a few options (1) New CiC £££££££ (2) Source a replacement used CiC (make sure the part numbers are the same) also be aware that it may need coding to your car (3) Last option is change the screen for one of the Android/Carplay options that are available they do work well
Good luck
13 hours ago, Greydog said:
Morning Dave
Good luck
Hi Dave,
Many thanks for the advice, will make some enquiries regarding getting the diagnostics carried out to find the issue.
Cheers
David
